Self-Shut Relay
Discussion in 'General Electronics Chat' started by alphi, Oct 21, 2009.
  1. alphi
    Jan 28, 2008
    9
    Dear all,
    What is self shut relay?
    where it can be used?
    How does it differes from the other type?
    Can anyone plz explain?
    Thanks in advance
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If a relay has normally closed contacts (NC), then those contacts will be closed and conducting with power to the coil removed.
    Some relays only have normally open (NO) contacts, and only conduct when energized. Some have both NC & NO contacts. Some only have the NC contacts.
  3. alphi
    Jan 28, 2008
    9
    So it means; self-shut relay is a NO relay.
    is it correct?
    regards,
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's not really a standard term. I see it as a relay that has a NC contact. - remove power and it makes the contact.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    If a little more context for that term were given, it would be easier to explain or to guess at what is meant. For example, is it from a motor-control circuit? Is it an English translation from another language?
    John
  6. alphi
    Jan 28, 2008
    9
    I got it from some automotive circuit used as ignition relay
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Was it a button start relay, where a momentary push on a button causes the relay to stay pulled in?
    John
