Self-inductance and Mutual inductance
Discussion in 'Homework Help' started by mo2015mo, Jul 12, 2013.
  1. mo2015mo
    May 9, 2013
    157
    Hi my friends :) ,,
    I having a problem and i tried to solve it as attached fig , I want you to verify the validity of my solution (because the choice questions is very precise)
      File size:
      258.4 KB
      49
  2. mo2015mo
    May 9, 2013
    157
    BTW.. the mutual inductance LAW between two solenoides is an approximation,,
    i found out it from the internet.
  3. mo2015mo
    May 9, 2013
    157
  4. Duane P Wetick
    Apr 23, 2009
    408
    19
    A straight forward approach may be used in calculating self inductances with no regard to other factors. For mutual inductances; other inductors in proximity to the first, calculus should be used because the influencing factors are in 3 dimensions to the first. For the final word on self and mutual inductances, see Inductance Calculations by Professor Frederick Grover, 1946, ISBN 0486495779
    Cheers, DPW [Everything has limitations...and I hate limitations.]
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    I'm guessing the OP is using simple ideal models for self & mutual inductance in which there is no leakage flux or partial self or mutual flux linkages. Such as one encounters for the infinitely long solenoid inductance model.
    The multiple choice answers offered suggest this is perhaps the case.
    The OP can rest assured the values obtained by them are OK in that context. Although, the supposed requirement for precision is debatable with respect to the answers both given & calculated.
