Self Cancelling Turn Signal LED Conversion
Discussion in 'The Projects Forum' started by MCForever, Mar 1, 2014.
Thread Status:
Not open for further replies.
  1. MCForever
    Mar 1, 2014
    5
    Hello. My first post! I have a 1982 Suzuki Katana with self cancelling turn signals that I would like to convert to LED's. Of course with just the LED connected, the light will not flash due to lack of current to the flasher unit. I wired a 1.5 ohm power resistor in parallel with the LED to increase the current load on the flasher unit. The flasher unit cycles at approximately the correct rate, but the LED does not light up.
    A lower resistance power resistor makes the flasher unit cycle faster, but the LED still does not light up. My guess is that the voltage is dropping below the LED threshold, but why does that occur in a parallel circuit?
    Thank you, Dean
  2. spinnaker
    Oct 29, 2009
    5,065
    1,163
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    The owners of All About Circuits have elected not to host discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
    This thread is against the AAC forum rules, Chapter 6, as seen here:
    This can be found in our Terms of Service (ToS).
    Automotive modifications of any kind are strictly forbidden. Therefore, this thread will be closed.
    Please try to understand the reasons behind this action, and feel free to browse and use the forums.
    There are other forums where you may be able to get some assistance.
    Good luck.
Thread Status:
