selection of opamp for high side shunt
Discussion in 'General Electronics Chat' started by ak52, May 11, 2016.
  1. ak52
    Oct 15, 2014
    145
    Hello Everyone,
    I am trying to implement a shunt resistor on the high side.
    I am finding it difficult to select the differential amplifier/opamp which amplifies the the voltage across the shunt.
    Here are my requirements.
    Input voltage : 150v DC.
    Range of current to be measured : 0 to 50A
    Vcc of opamp cannot be more than 5v
    I searched many places but my main issue is the Commom mode input voltage range,
    I couldn't find any opamp that can handle the high voltage.
    If anybody knows of such an amplifier please share the part number.
    Many thanks,
    AK
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,299
    Linear Tech makes special purpose diff amps for this application. They might be under "power management" on their website (instead of "instrumentation amps"). A common trick is to attenuate the two signals by something like 50:1 so the DC value falls within the diff amp CM range, the crank up the diff amp gain to get the current signal back without the DC.
    Another methoc is a transconductance amp that floats on the high DC voltage with an open collector PNP output stage. A scaling resistor to GND sets the output voltage / input current transfer function.
    ak
  3. crutschow
    Mar 14, 2008
    13,502
    3,376
    Google high voltage difference amplifier.
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
    The T.I. INA138 or INA168 are high side current sensors and there is an app note that shows how to use them at very high input voltages.
