Hey Guys,
I'm working on a project the uses a Pololu Orangutan. I will be modifying a dc signal that is from 1-4 volts. The first will be a differential op amp that will cut of the bottom of the signal and the second will scale it up.
I have no idea which op amps to purchase. I assume their power supply needs to be 5 volts and ground because I am using the orangutan.
Thanks in advance.
Thanks in advance.
