Selecting right soldering bit - weller
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Dec 25, 2014.
  1. Vindhyachal Takniki
    Nov 3, 2014
    358
    6
    1. I have a weller soldering station & need to search between right soldering bit.
    2. I have to select bit for WSP-80.
    3. I solder component liken QFP , SOT-223 , So-8 , TSOT23-5 & smd resistor & caps of 0603 , 0805.
    4. I have attached the pdf for the range of bits from which i can select.
    5. I have reading below website:
    http://www.hakko.com/english/tip_selection/work_drag.html#type_b
    So I think Shape B will be best suited for my requirement.
    6. So from attached choices,I have chosen
    "T005 44 489 99 , LT 1A , Round tip , width - 0.5mm , length = 14.0mm"
    7. Any suggestions?
