Selecting parameters and component values for delay circuits
Discussion in 'Homework Help' started by taiwoet@yahoo.com, Jul 11, 2011.
  1. taiwoet@yahoo.com
    Jul 11, 2011
    .wysiwyg { PADDING-BOTTOM: 0px; MARGIN: 5px 10px 10px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; FONT: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; BACKGROUND: #f5f5ff; COLOR: #000000; PADDING-TOP: 0px } .wysiwyg A:link { COLOR: #22229c } .wysiwyg_alink { COLOR: #22229c } .wysiwyg A:visited { COLOR: #22229c } .wysiwyg_avisited { COLOR: #22229c } .wysiwyg A:hover { COLOR: #ff4400 } .wysiwyg A:active { COLOR: #ff4400 } .wysiwyg_ahover { COLOR: #ff4400 } P { MARGIN: 0px } .inlineimg { VERTICAL-ALIGN: middle } In designing the delay system, a variable capacitor and variable resistor were alternately adjusted until a 5-second and 3-second required for supply changeover and generator starting system is achieved while one was kept constant in turn. These times correspond to the time contant of each circuit concerned. This is the principle used for selection of the two basic components constituting the delay circuits used for my project.
    My supervisor now ask me this question'' You are yet to tell me how you arrived at these parameter values i.e 470μf and 10.5k'' my response that the values are derived experimentally does not solve the problem.
    ''Can somebody please help me out?.''
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Your attachment did not work.
    Maybe you can try again using a more common format.
    hgmjr
  3. taiwoet@yahoo.com
    Jul 11, 2011
    Can l further experiment with Wheatstone Bridge and subsequently follow up the calculation procedures?, may be that will answer his questions.
    Thanks for the response.
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    Your circuit cannot be seen. Try to post your circuit by another method.
    Unless we can see your circuit, we cannot help you.
