Select source code
Discussion in 'Feedback and Suggestions' started by nerdegutta, Jul 29, 2015.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,569
    806
    Hi.
    Some years ago, we had a Select - button. It allowed us to select the source code, when the CODE - tag was used.
    What happened to it?
  2. ericgibbs
    Jan 29, 2010
    2,599
    394
    hi,
    Do you have this option, ref image.
  3. nerdegutta
    Dec 15, 2009
    2,569
    806
    Yes, but there was a button below the source frame.
    Code (C):
    1. void main(){
    2. while (1) {
    3. // do nothing, just wait
    4. }
    5. }
    6.
    There was a button that said select, and we could select all the source code, and hit CTRL+C, and paste in in wherever we'd like.
  4. nsaspook
    Aug 27, 2009
    3,017
    2,378
    How do you get rid of the line numbers in a Code section?
  5. tjohnson
    Dec 23, 2014
    618
    122
    That question has been asked before in the thread Small improvement to [CODE] tag.
    nsaspook likes this.
  6. nerdegutta
    Dec 15, 2009
    2,569
    806
    I do not know, but as @tjohnson says, quote or hit reply, then the source code shows up in the textbox. Mark and copy from there. No line numbers.
    I wonder what happened to the Select-button, thou...
  7. tjohnson
    Dec 23, 2014
    618
    122
    @nerdegutta: You don't even need to do that. Just try to mark and copy code within a post. The line numbers shouldn't get selected or copied.
  8. nerdegutta
    Dec 15, 2009
    2,569
    806
    You are quite right. Thanks.
    But what happened to the button?
  9. tjohnson
    Dec 23, 2014
    618
    122
    I haven't been a member of the forum long enough to know for sure, but I suspect that the Select button was part of the old vBulletin forum software. I don't know if XenForo supports this feature or not.
  10. nerdegutta
    Dec 15, 2009
    2,569
    806
    I'll guess you are right. Another thing I miss about the old forum...
  11. nsaspook
    Aug 27, 2009
    3,017
    2,378
    Thanks, it still looks like crap and should be turned off if possible.
