Seems simple...but cant get the answer
Discussion in 'Homework Help' started by saranya, Feb 19, 2005.
  1. saranya
    Feb 19, 2005
    Though I am familiar with kirchhoff's law and could solve most simple circuits, the following problem seems different. Any help is appreciated. Thanks.
    Problem:
    Four identical resistors ( R ) form 4 sides of a square. The ratio of the effective resistance between adjacent corners to that between opposite corner is
    a) 4 R B ) R/4 c) 3R/4 d) 4R/3
  2. pebe
    Oct 11, 2004
    628
    Assume each resistor=R. The resistance across opposite corners = R+R in parallel with R+R. So resistance across corners = R
    Between adjacent corners, R is in parallel with 3R (the other 3 resistors in series) = 3R/4
    So the ratio = R:3R/4
  3. saranya
    Feb 19, 2005
    thanks pebe for the clarification; the phrasing of the question is clear now.
