Seeking TPA3123 Not-Assembled Kit
Discussion in 'The Projects Forum' started by johnyradio, Oct 12, 2015.
  1. johnyradio
    Oct 26, 2012
    39
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    Its cheaper to buy it ready made, so do that and save yourself a lot of bother...
  3. johnyradio
    Oct 26, 2012
    39
    Thx, but i WANT to build it.
  4. GopherT
    Nov 23, 2012
    6,339
    4,083
    Then buy an assembled kit and a roll of solder wick.
  5. johnyradio
    Oct 26, 2012
    39
    this must be the comedy forum.
  6. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    ...Or buy some strip board and go to Digikey.
    Max.
  7. johnyradio
    Oct 26, 2012
    39
    thx, Max.
    i run an electronics education program for teenagers, and we prefer to work with kits. No janky stripboard stuff.
    if i can't find a kit, then it would be great to find just the PCB.
    if not that, then our next option is to etch our own boards.
    We're going for lowest parts count, so i like the assembled module linked in my first post.
    Going to be a BTL, so i believe we can eliminate the series caps on the output. Don't need the mute switch. May forego the shutdown pop protection.
    My plan is to use the BTL schematic in the datasheet as-is, but welcome any suggestions.
    http://www.ti.com/lit/ds/symlink/tpa3123d2.pdf
    thx!
  8. GopherT
    Nov 23, 2012
    6,339
    4,083
    Johny
    Are the teenagers newbies or experienced soldering technicians? If not, do you have a decent temp controlled soldering pencils for them to use? If not, I fear that you are expecting a lot for a first-timer to solder a 24-pin TSSOP smd chip.
    Let me know if you need any help. I applaud your effort.
  9. Dodgydave
    Jun 22, 2012
    5,167
    777
    Think you're better starting with a simpler kit, if you cant get that chip, try Velleman kits.
