Seeking software to design barcode on Windows PC
Discussion in 'Computing and Networks' started by chaarus, Sep 28, 2013.
  1. chaarus
    Sep 28, 2013
    I want to generate printable barcode for my manufacturing business items. Is there any software to design barcode on Windows installed personal computer system?
  2. t06afre
    May 11, 2009
    5,939
    1,222
  3. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  4. gresha
    Sep 30, 2013
  5. sirch2
    Jan 21, 2013
    1,008
    351
    Whilst there are things like Barode Fonts which tend to come with barcode printers, at the most fundamental, a barcode is just a series of variable width black rectangles at variable spacings. It is perfectly possible to just print the rectangles, I have done this in the past but don't have the code available, I'm sure Google will help.
    You should also be aware that there are different barcode symbologies and not all readers can read all symbologies
  6. MagicMatt
    Member
    Sep 30, 2013
    117
    14
    If this is for professional use, for retail as an example, you will probably need to register the codes you want to use. The company that do this usually supply free bar code software.
