Seeking Sine Wave IC - 5kHz
fsonnichsen
Joined Jun 6, 2013
49
I need a compact sine wave generator (~5V) for a 2x2" circuit board. Around 5kHz.
I have used a few ICs for this in the past but they are obsoleted! Noise is an issue and my few op-amp designs have more EMI than a compact chip.
Anyone out there have a favorite that they have found to be fairly "quiet". Stability and accuracy not an issue here--
cheers
Fritz
THE_RB
Joined Feb 11, 2008
5,438
A really "quiet" sine oscillator is a single transistor phase shift oscillator which runs linearly and has no crossover or current peak issues, and is easily small enough to fit on your PCB.
Since you said stability and accuracy (freq? waveform?) is not critical that should do the trick.
GopherT
Joined Nov 23, 2012
8,009
For those that have to have one, here you go. Not cheap @ $7.50 ea.
About halfway down the page..
http://www.elexp.com/ics_10cn.htm
EBay has them for only $3.29 with free shipping (2.30 in quantities of 10). Seller Tayda seems to have a US shipping point because I get their stuff in a few days. They also have a website Taydaelectronics.com but the have a $5 minimum and charge a buck for shipping. EBay is the better deal for one or two.
http://www.ebay.com/itm/XR-2206-XR2...111?pt=LH_DefaultDomain_0&hash=item4163c7e1df
fsonnichsen
Joined Jun 6, 2013
49
Thanks for the replies. Jeessh-I thought there would be a lot of sine ICs out there these days but in fact searching the digikey database there are very few and none stocked. Unobtainium as we say! Mouser had their last three XR2206 in the solar system for $71/each! I can probably buy complete B&K func-gen for that price. In a few years couples will be getting sine ICs mounted into engagement rings (;->
No surprise some respondents just do it the old fashioned way and grow their own-more fun at least. At any rate i'll clean up my old design and meanwhile place an ebay order. BTW - The MAX038, also obsolete looks interesting-
cheers
Fritz
ScottWang
Joined Aug 23, 2012
7,399
1. NE555 50% duty cycle 5Khz astable circuit → RC integrating circuit → bjt amplifier.
2. NE555 50% duty cycle 5Khz astable circuit → LC integrating circuit. (adjust the amplitude)
THE_RB
Joined Feb 11, 2008
5,438
