IE6 also has a View Source capability. Right-click the page in question, and select View Source. That opens a Notepad window, and from there you can save the file.I don't use IE7.0, and won't unless I absolutely have too. The markup codes are coming through on IE6, this isn't HTML.
You could very well be right Mark, I went off the descriptor:The MS download that Dave pointed you to can be used to validate XML or XML transforms, which I don't think you need to do.
XSL and XML are interrelated, but I cannot say for sure whether this is going to sort Bill's problem.Currently, when browsing XML files using Microsoft® Internet Explorer, the XML documents are not validated. In addition, when viewing the source of the document, only the XML is returned and there is no way to view the output from the XSL or XSLT style sheet that may have been used to transform that XML document.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" />
<meta name="generator" content="vBulletin 3.7.0" />
<meta name="keywords" content=" Seeing XML offline, forum,circuits,electric,electrical,electronics,projects,engineering,math,physics,robotics" />
<meta name="description" content=" Seeing XML offline Off-Topic" />
<!-- CSS Stylesheet -->
<style type="text/css" id="vbulletin_css">
* vBulletin 3.7.0 CSS
* Style: 'Default Style'; Style ID: 1
@import url("clientscript/vbulletin_css/style-83a138d0-00001.css");
</style>
<link rel="stylesheet" type="text/css" href="clientscript/vbulletin_important.css?v=370" />
<!-- / CSS Stylesheet -->
<script type="text/javascript" src="clientscript/yui/yahoo-dom-event/yahoo-dom-event.js?v=370"></script>
<script type="text/javascript" src="clientscript/yui/connection/connection-min.js?v=370"></script>
<script type="text/javascript">
var SESSIONURL = "";
var SECURITYTOKEN = "1ce3e0d52b251c76c09b2f4244d0b8c325f7a2a7";
var IMGDIR_MISC = "images/misc";
var vb_disable_ajax = parseInt("0", 10);
</script>
<script type="text/javascript" src="clientscript/vbulletin_global.js?v=370"></script>
<script type="text/javascript" src="clientscript/vbulletin_menu.js?v=370"></script>
<link rel="alternate" type="application/rss+xml" title="All About Circuits RSS Feed" href="external.php?type=RSS2" />
<link rel="alternate" type="application/rss+xml" title="All About Circuits Blog RSS Feed" href="http://forum.allaboutcircuits.com/blog_external.php" />
<link rel="alternate" type="application/rss+xml" title="All About Circuits - Off-Topic - RSS Feed" href="external.php?type=RSS2&forumids=10" />
additional text omitted...
by Duane Benson
by Duane Benson
by Duane Benson
by Aaron Carman
