see these.
Discussion in 'Computing and Networks' started by atotoarere, Jan 8, 2007.
  1. atotoarere
    Nov 27, 2006
    8
    A. How can i convert these folllowing number to (1)BINARY (2)OCTAL (3)HEXADECIMAL,
    195, 248, 3216.
    B. advantages and disadvantage of network TOPORLOGY?
    C. advantage of magnetic disc over magnetic tape as a storage medium?
    D. what is system analys and design?
    E. MULTITASKING, MULTIPROCESSING, MILTIPROGRAMME are function of what
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Some study on your part is called for. We are here to aid in specific questions, but not on very broad topics.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Volume 4 - Chapter 1 - Numeration Systems
    If you wish to give the question a go and post your answers up, we can check to see if they are correct. If you get it wrong we can point you in the right direction based on your answers.
    Dave
  4. alitex
    Mar 5, 2007
    122
    you should convert any number u want to binary after that u can convert result to any system u want
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You shouldn't have to convert to binary, provided you understand the relationshipd between the different numeration systems you can do a direct conversion. Granted you may feel it is easier to convert to binary or decimal first since you are most familiar with these numeration systems.
    Dave
