Sedimentation - Spherical Particles
Discussion in 'Physics' started by boks, May 2, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    a) v = \frac{2 R_s^2 (\rho_silica - \rho_water)g}{9 \eta}
    b) t = s/v = 5.1*10^4 s
    c) I don't see how this could be done without centrifuging the cylinder. Perhaps that's what they're aiming at?
  2. PRS
    Aug 24, 2008
    989
    35
    I think it involves changing the water with an additive to change its p. This is predicted by the equation.
  3. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Other than additives you could:
    increase g (centrifuge)
    increase size of particles
    reduce temperature
  4. PRS
    Aug 24, 2008
    989
    35
    You're probably right, BillO, but why would changing the size of the particles speed their velocity?
  5. studiot
    Nov 9, 2007
    5,005
    515
    The point of the additive is to reduce the viscoscity of the water, (the denominator in the equation) which will have a more dramatic effect than attempting to change the density.
    So add some Fairy Liquid.
    As Bill says the biggest effect is to increase particle size since the mass increase as the cube of the radius, whereas the surface and therefore the friction as the square.
    But I am not sure this is a legitimate answer any more than replacing the silica with lead shot of the same size would be. I expect you are meant to make the existing sample sediment faster, not change it for a different one.
  6. PRS
    Aug 24, 2008
    989
    35
    That was my point and it's predicted by the given equation, scroll up.
    I was taught in physics that you can drop a steel ball bearing and a steel bowling ball at the same time from a two story window and they hit the surface at the same time. Surface area was not a thing. So is it that in a fluid it is more of a thing to think about? Mind you I was not arguing, just asking.
    No, I think you can't replace the silica, that's cheating.
  7. studiot
    Nov 9, 2007
    5,005
    515
    In this situation the force due to the weight of either ball dwarfs the frictional resistance of the air.
    Sedimentation is about when the frictional forces opposing settlement under gravity are of comparable magnitude to the gravitational forces due to the weight of the particles. This would also happen if one of your balls had a parachute!
    Small point: η is the viscosity, - not ρ which is the density in Boks equation.
  8. PRS
    Aug 24, 2008
    989
    35
    Thanks, Studiot. For some reason I never ran into Boks equation while at school. What you said makes good sense.
