Hi All
first i would like to thank you all for your help and suggestions.
i am undergoing a project which consists building and controlling a robot through wifi network. the robot is prity basic, only two moters and a camera. the motors are used to direct the camera right and left, up and down (360 degrees rotation). the robot have to be controlled from long distances.
the only problem for me is communication and controlling as it will be a security robot. so the only way i could think of doing it, ''Cheaply'' is by using a wifi router. connecting the joystick controller to it (through wifi) and conecting the robot to the wifi router (MCU to wifi router through Ethernet).
is this possible?
will i be able to recieve data back and forth through the wifi router?
what microcontroller should i use for this Robot?
any other ideas and suggestions can you guys give me?
please help as i am only a newbee and need some support.
thanks alot for your help.
regards
is this possible?
regards
