secondary line constants
Discussion in 'General Electronics Chat' started by gorgondrak, Nov 27, 2014.
  1. gorgondrak
    Nov 17, 2014
    61
    When dealing with secondary line constants of a transmission line, what exactly is attenuated by the real component of the propagation constant if the losses in the line due to resistance and conductance are already accounted for in the characteristic impedance?
    Papabravo likes this.
  2. crutschow
    Mar 14, 2008
    13,509
    3,385
    Sounds like a homework question.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What is attenuated by the real component is the amplitude of the signal propagating down the line
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Characteristic impedance is usually expressed as the magnitude of a complex quantity. It's primary usage is to terminate the line with an impedance of the proper magnitude to prevent reflections. The propagation constant is used to decide how much power you need to put into a line of a given length in order to have a useable amount of power coming out.
