second question
Discussion in 'Homework Help' started by urchik, Mar 8, 2007.
  1. urchik
    Mar 8, 2007
    12
    also, can someone explain or direct me into understanding bool identities, I need to prove that xz = ( x + y ) ( x+y' ) ( x' + z )
    so I did the truth table as follows:
    XZ =
    X Z X&Z
    0 0 0
    0 1 0
    1 0 0
    1 1 1
    and ( x + y ) ( x+y' ) ( x' + z ) as follows:
    0 | 0 | 0 | 0 0 1 1 0
    0 | 0 | 1 | 0 0 1 1 0
    0 | 1 | 0 | 1 0 0 0 0
    0 | 1 | 1 | 1 0 0 0 0
    1 | 0 | 0 | 1 1 1 1 0
    1 | 0 | 1 | 1 1 1 1 1
    1 | 1 | 0 | 1 1 1 0 0
    1 | 1 | 1 | 1 1 1 0 1
    is that correct?
    Also the identities are as follows:
    XX+XX’+YX+YY’+YZ+XX’+XZ+Y’X’+Y’Z ;Distributive
    XX+(XX’)+YX+(YY’)+YZ+(XX’)+XZ+Y’X’+Y’Z ; Associative
    XX+YX+YZ+XZ+Y’X’+Y’Z ; Inverse
    and I'm stuck. Can anyone direct me to teach me how to do this... I read alot of articles but I dont understand much for it. Thanks!
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    First things first. Can I ask to you clarify what you are doing here? I am struggling to follow what you have done. If need be scribble it down on paper, scan it into your computer and upload it to the forums.
    Dave
  3. urchik
    Mar 8, 2007
    12
    Sorry, I should have been more clear.
    What I need to do is prove that xz = ( x + y ) ( x + y' ) ( x' + z )
    First part asks to prove it using a truth table. Now I constructed a truth table for both and here they are:
    for XZ:
    X Z X&Z
    0 0 0
    0 1 0
    1 0 0
    1 1 1
    and for ( x + y ) ( x + y' ) ( x' + z ):
    Last row being the Q or the output. They don't match as you see... am I doing something wrong here? The next step in this assignment is to prove the same problem but only using boolean identities which I'm stuck on as well, this is what I did so far:
    Can you guide me or help me in this problem.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ok, lets deal with proof by truth table first. I am still at a loss as to how you are getting the outputs as 5-bits long. For each input combination for x, y and z then the expression will evaluate to '0' or '1'.
    For example:
    ( x + y ) ( x + y' ) ( x' + z ) for x = 0, y = 0, z = 0
    ( 0 + 0 ) ( 0 + 1 ) ( 1 + 0 ) = 0
    You need to do this for each input combination. What you will see is that in the resulting truth table, you can ignore the variable Y, from which you can simplify the truth table to original truth table for XZ (I haven't done this, but this is how you would do it).
    I suggest you know together the truth table for ( x + y ) ( x + y' ) ( x' + z ) as I have shown above and post it up here, from there I can show you how interpret the truth table to prove the expression is equal to XZ.
    Dave
  5. urchik
    Mar 8, 2007
    12
    sorry for the confusion, maybe this will help. The output (truth table) for the long expression is :
    hope this helps, I did this into a truth table program so you can see things clearly.
    I still don't see how xy can equal to that...the only thing I can think of is to simplify ( x + y ) ( x + y' ) ( x' + z ) into something that will equal to xy when constructing the truth table.
    After this, I have to prove the same thing but only using boolean identities.
