Second order circuit - zero imput response
Discussion in 'Homework Help' started by omar-rodriguez, Mar 8, 2016.
  1. omar-rodriguez
    Jun 24, 2015
    51
    Hello, I have spent a lot of time trying to understand why I can't do this exercise by two different ways and find the same result.
    I have to find Vc1(t) t ≥ 0 by two ways
    1. first find the differential equation and then apply laplace transformation
    2. second analyzing the circuit directly in the frequency domain
    Solution:
    1. find the differential equation and then apply laplace transformation
    2. analyzing the circuit directly in the frequency domain
    as you can see both answers are different and this this makes no sense..... I really don't know why HELP!!!
  2. anhnha
    Apr 19, 2012
    776
    48
    Your first solution is wrong.
    First, for the integral, you should take limits into account. By the way, why don't you Laplace and solve for I(s) in method 1?
  3. omar-rodriguez
    Jun 24, 2015
    51
    I put the initial conditions after transform the differential equation
  4. anhnha
    Apr 19, 2012
    776
    48
    Here is my result when solve for V1(t):
    omar-rodriguez likes this.
  5. omar-rodriguez
    Jun 24, 2015
    51
    Great!!, finally I undestood my mistake thank you
