Second Order Circuit: Sim vs. Algebraic Solution
mjakov
Joined Feb 13, 2014
20
Dear forum experts!
Please help explain the inconsistency between the algebraic solution and LTSpice simulation for a second order parallel circuit here. The parameters are:
R=200 \Omega, L = 0.28H, C = 3.57 \mu F
The capacitor ought to have an initial voltage of 50V. Hence, I us the .ic command in the sim to set the initial voltage for the identifier n001. This identifier seems to correspond with the node above the capacitor.
By calculating the circuit algebraically it can be shown that the RLC parameters result in an underdamped (oscillatory) case. The algebraic equation for the circuit is:
\( v(t) = e^{-700t} * (50 cos (714t) - 49 sin (714t)) \)
Below you can see the plot of this equation until 10 ms.
The image below shows the simulation. Besides some similarity in the curve shape, the values on the y-axis seem to be off by a factor of \( 10^6 \).
My assumption is that there is something wrong with the simulation, since the algebraic solution has been derived according to my textbook. Could someone please give a hint as to what could be wrong. Other circuits that I have simulated without the initial conditions seemed to be OK in LTSpice. Could it be that one should use the switch element in the sim, e.g., first to charge the capacitor with a source and then move a switch to a desired position?
MikeML
5,444
Majkov,
I believe LTSpice over your algebra...;) It did exactly what you told it to do...
Eric showed you how to name a node in an LTSpice schematic, so that you can refer to its given name in the .IC V(name)= XX or plot statement.
The use of the uic in the simulation directive forces the current in the inductor to be zero at time=0. Otherwise, the inductor current would be nearly infinite at time=0, which is what happened in your original sim, and you would have seen if you added the current through L1 to the plot as below...
The better way to do this using a more complex .IC statement is shown below. The LTSpice help file strongly discourages ever using the uic directive. In a more complex circuit, it can lead to unpredictable results.
ericgibbs
Joined Jan 29, 2010
18,862
Mike,
The uic is still in common usage in many tutorials and examples, however I will look thru more documentation.
Eric
Query: have you edited your post since I last read it.:rolleyes:
MikeML
5,444
Mike,
Eric
Yep. Here is the description of uic:
Here is .ic
