Searching for Logic Level Mosfets using parametric search?
Discussion in 'General Electronics Chat' started by spinnaker, Oct 25, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,103
    1,192
    How would I use a parametric search like the one from Mouser to do a search for logic level mosfets?
    Note to admins: Perhaps this can be moved to the Embedded forum and made a sticky once there is an answer?
    And fix the spelling in the title (Searching) please? :)
  2. Ron H
    Apr 14, 2005
    7,050
    657
    You might want to test your link. It does not go to Mouser.
    Here's how I would do it: Go to Mouser.com and
    1. Type "logic level" in the search window.
    2. Select "discrete semiconductors"
    3. Select "MOSFET"
    4. All the parts in the parametric table are logic level MOSFETs.
  3. spinnaker
    Oct 29, 2009
    5,103
    1,192
    Thanks link fixed. Working with too many links. :)
    I understand logic level is just a marketing tool. It would be nice to know what parameters to select without the use of "logic level".
  4. Ron H
    Apr 14, 2005
    7,050
    657
    What do you mean, "marketing tool"? The search I specified (should) narrow the search down to devices whose Rds(on) is specified for Vgs<=5V. Unfortunately, Mouser does not specify Vgs for the Rds spec. I don't see that there is any other way to find logic level devices on the Mouser site.
    Maybe someone else does.
  5. spinnaker
    Oct 29, 2009
    5,103
    1,192
    Basically it is really the specs on the mosfet that makes it a logic level like the one you specified.
    OK so the way I understand it is that you want a low RDS(on) for low power dissipation?
    I need to switch <1 amp at 12Volts. Since this the project is powered from a battery I want the circuit to be as efficient as reasonably possible.
    Is this a good choice?
    http://www.mouser.com/ProductDetail...=sGAEpiMZZMvsEea7gdidXoi8LyX0IJAmNhy8rLTLpbc=
  6. crutschow
    Mar 14, 2008
    13,518
    3,386
    "Logic Level" means that the lowest ON resistance for the MOSFET, when used as a switch, can be achieved with logic level (typically 5V and sometimes 3.3V) Vgs. It does not necessarily mean it has the lowest ON resistance. Standard MOSFETs (which typically require 10V Vgs for minimum ON resistance) can also have a low ON resistance.
    The main reason to buy a Logic Level device is if you don't have 10V to turn it on.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    You could use a 20V MOSFET specified for 2 Amps. A 12V battery might have considerable internal resistance already, so 0.5 Ohms (at less than 1 Amp) don't really count.
    If you want to buy 100pcs for $50 or 200pcs for $100, yes good choice.
