Searching for an alternative component
Discussion in 'Electronics Resources' started by Abhinavrajan, Aug 29, 2016.
  1. Abhinavrajan
    Aug 7, 2016
    77
    I have a microcontroller chip. But it seems to be very expensive.
    How do I choose another less expensive microcontroller chip which has the same features as the initial one
    without compromising any of the facilities?
    How do I go about? or What should I search?
    What should be my approach while selecting an alternative chip?
  2. RichardO
    May 4, 2013
    1,342
    431
    Can you tell the part number of the "expensive" chip? And, how "expensive" it is?
    Be warned that microcontrollers usually do not have exact replacements available for any cost. There may or may not be a similar part that is cheaper. Probably not.
  3. OBW0549
    Mar 2, 2015
    1,396
    941
    All you can do is start digging: make note of the features you need, and start going through the various manufacturers' offerings looking for something that will do the job. I don't know about any shortcut around that.
    Abhinavrajan likes this.
  4. Abhinavrajan
    Aug 7, 2016
    77
    Thanks ;)
