Searching for a small 5vdc/230vac ssr, or a discrete circuit for same.
Discussion in 'General Electronics Chat' started by sternpirate, Oct 2, 2016.
  1. sternpirate
    Dec 10, 2015
    8
    I built a project based around an arduino controlled fotek solid state relay, and hired a welder to have a case made from stainless steel. But when I received it back the case is 10 mm too small for the relay breadth, width and length are fine. I have sufficient length to fit a relay twice as long. I bought an omron mechanical relay rated at 10 amps but I don't think it will last as I need to run 2.5kw through it. So does anyone know anyone who makes a long relay or point me to a circuit to make my own. I don't need pwm or dimmer, simple on/ off is fine.
    edit. the 2.5kw load is a water heater coil so entirely resistive.
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    What is the length, width, and height available in the case for an SSR or relay?
    Ken
  3. sternpirate
    Dec 10, 2015
    8
  4. sternpirate
    Dec 10, 2015
    8
    i bought the sharp ssr, mods can close the thread
