Search function not working?
Discussion in 'Feedback and Suggestions' started by coldpenguin, Feb 27, 2011.
  1. coldpenguin
    Thread Starter Active Member
    Apr 18, 2010
    165
    9
    Hi all,
    Is it just me, or is the search function broken? All I get is a blank page returned.
    I am trying to search on something similar to:
    high current pwm voltage
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    When you leave the voltage out it will work.
    With the four items I also get a blank page.
    Bertus
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    It seems to be working now.
    John
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    There are different aspects to search. When ever I use it I go for advanced, it tends to be a bit more reliable.
    I tried it using the simple function, it does indeed seem broken.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Still works for me with the four items. Are you separating them with commas? If I didn't use commas with the four, then I got a blank page. I tried a couple of other four-item searches with commas, and had no problems.
    In fact, it seems any search for two or more terms must be separated by commas.
    John
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Nope, I didn't. I don't think it is a requirement either. The screen is white and not changing, no text, which in my book means broken.
    Only reason I haven't seen it is I always click advanced search.
  7. jrap
    Administrator
    Jun 25, 2006
    966
    202
    I rebuilt the search index in an attempt to fix this error - but I'm assuming it's just the fact that vB search is far from perfect. A search for a combination of popular keywords like "high current pwm voltage" may just overrun the search. When in doubt, use the search bar at the top - it's powered by Google.
    Rob
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    Separating the terms with a comma works. Maybe it needs that for the "and."
    John
