Hello:
I have read the following specifications about PC Game Joystick Port:
Pin Name Dir Description 1 +5V OUT +5 VDC 2 /B1 IN Button 1 3 X1 IN Joystick 1 - X 4 GND - Ground 5 GND - Ground 6 Y1 IN Joystick 1 - Y 7 /B2 IN Button 2 8 +5V OUT +5 VDC 9 +5V OUT +5 VDC 10 /B3 IN Button 3 11 X2 IN Joystick 2 - X 12 GND - Ground (shared with MIDI_OUT, see PC MIDI + game port) 13 Y2 IN Joystick 2 - Y 14 /B4 IN Button 4 15 +5V OUT +5 VDC (shared with MIDI_IN, see PC MIDI + game port) Axis signals
These pins are analog inputs and must be between 0 and 5 volts, 0 volts represents 0 (00000000 in binary) and 5 volts represents 255 (11111111 in binary). When a digital joystick is used, they generaly send a 2.5 volts signal when no buttons is pressed, go down to 0 volts when the up or left button is pressed and 5 volts when the down or right button is pressed.
I am a bit confused. I saw that´s usual Joysticks are connected using 100 Kohms potentiometers, between pins 1 - 3 or 1- 6 . Does the note above mean that I can put any 0-5 Volts source voltage and it will be accepted by the PC interface, and used as legal input ?.
In others words, is the 100 Kohms specification one way to obtain a signal using the +5 Volts built-in provided by pin 1, but if required, there can be used other outlines ?
I would appreciate any explanation.
My best regards.
Roberto
My best regards.
Roberto
