Search for parts
Discussion in 'General Electronics Chat' started by Oussama Zaidi, Apr 30, 2016.
  1. Oussama Zaidi
    Mar 1, 2016
    53
    Hi
    In my project, I wanna use an 8 BJT transistors integrated circuit, I do some researchers and I found two "M6380" and "M54513" I found a lot of Darlington arrays but I don't need Darlington circuits just normal 8 transistors IC like in the links above, the problem is I can't found any of the 2 circuits in sites like Digikey or mouser electronics they don't exist at all so I am wondering if they still exist in the stores or not, does anyone has an idea about that or he knows another part like them?? thank you.
    http://www.me-sh.cn/products/pdf/m63805p_e.pdf
    https://www.mitsubishielectric-mesh.com/products/pdf/m54513p_e.pdf
  2. GopherT
    Nov 23, 2012
    6,304
    4,027
    I searched for similar recently. An 8-transistor array does not exist unless it is Darlington. 4-NPN array exists and you have access to all three pins (no common pins) in this one. I don't know your current/load expectations but 4-transistors arrays are your only option unless you go with darlington.
    http://www.digikey.com/product-detail/en/fairchild-semiconductor/MMPQ3904/MMPQ3904FSCT-ND/1626262
