Sealed Batteries
Discussion in 'General Electronics Chat' started by R!f@@, Mar 7, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,791
    771
    I got these two.
    Both is around 8V.
    Takes very low charging current and handles light loads.
    I like to know whether I can revive these ?
  2. t06afre
    May 11, 2009
    5,939
    1,222
    R!f@@ likes this.
  3. mcgyvr
    Oct 15, 2009
    4,791
    975
    In general its not worth your time to try to revive a SLA battery. Once sulfation has set it you are better off just buying a new one.
    Sometimes you can just fully charge it then let it sit for a day or two then charge again and again.. Other times an over-voltage charge might work.. But in general it never really works well with SLA batteries.
  4. jimkeith
    Oct 26, 2011
    539
    99
    What I have observed with dead gel cells is that if you apply a high voltage (e.g. 25V) and monitor the current, you can predict what will happen. If the current decreases, the battery is likely history--if the current gradually increases (possibly unstable at times), it will continue to increase and will eventually start taking a reasonable charge, at which time you start reducing the voltage.
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    Won't applying high voltage is dangerous.
  6. jimkeith
    Oct 26, 2011
    539
    99
    Limit the current to perhaps 0.5A via series resistor or current limited PS and there is little danger--of course wear your safety glasses if you have your face in it.
    The only time I had a lead-acid battery blow up was when my engine timing light clip came off the spark plug and came to rest on the case of the battery. Fortunately, the blast (pop) soaked my sweat shirt with acid rather than my face--later the sweat shirt looked like it had been hit with a shotgun blast. One of my many survivor incidents...
  7. t06afre
    May 11, 2009
    5,939
    1,222
    An interesting tip. Lead acid batteries may in some deap discharge cases get something that is it is referred to as "cell reversal. it is possible for one or more cells to reverse polarity. One cure for this as I have heard is charging the battery with overvoltage. But I do not know if this is true or not. Doing some quick Google serch. I found out that the most common tip to fix "cell reversal". Is to compleatly discharge the battery and then Then recharge at VERY LOW charge rates. But I have no personal experince with this in any way.
  8. R!f@@
    Apr 2, 2009
    8,791
    771
    I have problem with building the de-sulphator. I got no way of measuring the inductance of the inductors I can get.
  9. t06afre
    May 11, 2009
    5,939
    1,222
  10. jimkeith
    Oct 26, 2011
    539
    99
    I know this happens with NiCads--causes cells to short--may be cleared via momentary high current charge.
    Never heard about lead-acid doing this, but since multiple cells are connected in series and do not all discharge to zero at the same time, it has to happen.
    Completely discharging the battery guarantees that more cells will be reversed--probably not a good idea.
  11. hwy101
    May 23, 2009
    91
    28
    On my other forum with EBikes we have had some success with those batteries if they are less than 5 - 6 years old, the cells dry out.
    Pry off the top plastic cover and you will see the rubber caps for each cell.
    Add a little distilled water to each cell (NOT TAP WATER) just enough to reach the top of the plates, don't over fill.
    Then recharge the battery again, this should be done outside, not indoors.
    R!f@@ likes this.
  12. R!f@@
    Apr 2, 2009
    8,791
    771
    U think I can top up these.
  13. hwy101
    May 23, 2009
    91
    28
    Get some distilled water from a hardware store, wont cost much.
    If you don't try, you'll never know.
  14. #12
    Nov 30, 2010
    16,685
    7,327
    Look at my blogs for an inductance measuring circuit.
    R!f@@ likes this.
  15. soda
    Dec 7, 2008
    174
    13
    Hi Rifaa,
    Something useful about SLA battery's to read
