SD card *minimum* SPI clock speed?
Discussion in 'The Projects Forum' started by autorelease, May 12, 2010.
  1. autorelease
    Thread Starter Active Member
    Jan 26, 2009
    39
    I'd like to add an SD card slot to the 8-bit computer I'm building. My idea is to implement a bit-banged SPI interface, but since the CPU clock speed is so low (1MHz), the SCLK frequency will be very low; 100kHz or lower.
    I know that SD cards have maximum SPI clock frequencies; do they have minimum clock frequencies? Or can the master toggle the clock line as slow as it wants to?
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Often it's DC as it's a static clock, but always check the datasheet.
  3. kubeek
    Sep 20, 2005
    4,686
    805
    IIRC the clock can be kept waiting as long as you need. But the mmc and sd specification is always handy if you want to communicate with the card correctly
