Screen Capture
Discussion in 'Off-Topic' started by Lightfire, Oct 31, 2013.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Do any of you know a program that captures a screen (obviously of another program :D) without capturing also the border (the title bar, minimize bar, etc.)?
    There are lots of screen capturing program but yeah they capture also the borders (Like alt + print screen), I just want the exact screen.
    I know you can just use snipping tool but yeah, my hands not perfect. There may also be some residue (border) left that I have noticed.
    Thank you!
  2. Ramussons
    May 3, 2013
    561
    92
    Screen Capture is literally Screen Capture. The "border", "Title bar" are all part of the screen. They will be captured.
    Try editing the capture using "cropping" where your hands are not the ones to define the "cropping" limits.
    Ramesh
  3. Nykolas
    Member
    Aug 27, 2013
    92
    31
    Try MWSnap. It allows you to size the capture area. E
    absf and Lightfire like this.
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    The snipping tool in Win 7 will allow you to snip a single window instead of the whole screen.
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Screen Capture has a capture active window option. I think this is what you want.
    EDIT: tracecom is right, there is also a built-in window capture option for the default snipping tool. Just click the arrow next to "new" and select "Window Snip".
  6. Lightfire
    Oct 5, 2010
    690
    21
    That is why I specifically said in my post:
    Do any of you know a program that captures a screen (obviously of another program ) without capturing also the border (the title bar, minimize bar, etc.)?
    P.S. How do you crop without using your hands?
    I know that. Alternatively you can just hold alt and press Print Screen and then paste it to Paint. But the border is still there. I just want the very inside.
    Any help??
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Guess my suggestion won't work either then, since it includes things like the tabs in the browser window....
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I suggest trying Greenshot. It's a fantastic program that has a lot of options. It is automatically activated when you hit the prtsc button and it has a large magnifying window above your cursor, so you can see exactly where you're putting it. It will help you cut out the borders.
  9. Lightfire
    Oct 5, 2010
    690
    21
    Nykolas's suggestion seems to work.
    I have attached one and it's very smooth and clear compared to snipping tools.
    P.S. Sorry it's very big (filesize).. but yeah it works!!!
    But still in others, it does not. It still includes borders.
  10. Brownout
    Jan 10, 2012
    2,375
    998
    You need not capture the boarder with Snipping Tool. You can select what part of a window to capture.
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    He was saying he doesn't want to manually outline the window because he doesn't have steady hands. The Snipping Tool does not have an automatic window capture that gets just what's inside the border, it can only capture the full screen, full window (including borders), or a user-defined area (which must be outlined manually).
  12. Lightfire
    Oct 5, 2010
    690
    21
    Not that not steady but yeah it's not perfect.
    I may just zoom and zoom it and then cut it. (zoom=larger=more accurate)
    Thanks everyone.!
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Like I said, Greenshot gives you a magnifier with crosshairs that allow you to pinpoint the border exactly. I can't recommend this program enough.
  14. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Down load IrfanView a freebie that all that and more.
    Max.
  15. WBahn
    Mar 31, 2012
    18,080
    4,917
    I use CaptureWiz from PixelMetrics. It's not free (has a very generous trial period, though) but it is quite inexpensive. It will automatically guess on which part of the screen you want, but also allows you to very intuitively define your own capture area. One of the nice things about it is that you can set up a capture window and then scroll the screen through it in order to capture stuff that doesn't all fit on the screen at one time. If you've selected one of the identifiable screen areas, then it will automatically scroll and capture the entire window. It has lots of other useful features for people putting together demos, recorded presentations, and the like that I haven't played around with much.
    DerStrom8 likes this.
  16. Brownout
    Jan 10, 2012
    2,375
    998
    Best idea, zoom, snip, done. It's not all that hard to get the inside of a window. You just drag a box from corner to corner of the area of interest.
  17. JoeJester
    Apr 26, 2005
    3,393
    1,211
    I've used the free Camstudio in the past to capture the screen ...especially when doing a simulation in the transient mode.
    I've also just did a print screen, paste, save, and then crop the picture.
    I've been doing the second recommendation a lot longer than the first.
  18. Ramussons
    May 3, 2013
    561
    92
    Try this
    Quick JPEG Image Resize and Crop
    You can crop by numerical entry instead of defining boundaries using a cursor.
    Ramesh
  19. atferrari
    Jan 6, 2004
    2,663
    783
    Captured the screen ( Alt + Print Scrn) to Clipboard then IrfanView and eventual changes with Paint.
  20. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Alt-Prt Scrn captures the open window.
    Ctrl-Prt Scrn captures the whole screen.
