SCR triggering
Discussion in 'The Projects Forum' started by madmantrapper, Jun 16, 2013.
  1. madmantrapper
    Apr 20, 2011
    15
    OK folks this may get a little long winded. I have two magnets rotating on a flywheel 180 degrees from each other. The magnet poles are reversed. What I want to do is have a charge coil and a trigger coil. The magnet will pass the charge coil ( north to south) to charge a capacitor. At a given distance later the magnet will pass the trigger (north to south). The magnet passing the trigger will fire an SCR discharging it through another coil. 180 degrees from there another magnet will pass the charge coil again, this time south to north, and then again pass the trigger coil firing a different SCR discharging the capacitor through another coil.
    The charge coil will produce about 300 volts. The trigger I'm not sure about. I have a sketch of the circuit I could post if I knew how.
  2. wayneh
    Sep 9, 2010
    12,384
    3,241
    That would help. Try taking a screen shot and attaching it to your post. New visitors may be restricted in what they can attach, not sure.
  3. sq-aristo
    Jun 1, 2013
    20
    I'm pretty sure the old outboard cap discharge packs used a Darlington transistor
  4. madmantrapper
    Apr 20, 2011
    15
  5. Dodgydave
    Jun 22, 2012
    5,153
    770
    What speed is this rotating at?
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Sounds like a capacitor discharge ignition circuit.
    If you google for some schematics there should be a lot of info out there.
    sq-aristo likes this.
  7. madmantrapper
    Apr 20, 2011
    15
    Flywheel is turning at about 7,000 rpm.
    Yes it is a capacitor discharge ignition. I am trying to duplicate a power pack. This thing blows often at $80 a clip. I figured I would make my own for near free.
    I have searched the web and found can't find anything to work.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    What does the engine connect to?
  9. madmantrapper
    Apr 20, 2011
    15
    It is a Johnson outboard 15 hp.
  10. sq-aristo
    Jun 1, 2013
    20
    A failing power pack is usually a symptom of another fault. Check all connections are tight and clean. I have seen charge and trigger coils on there way out surge and kill power packs. If you have a service manual or the specs and a peak voltage adapter measure the output of charge and trigger coils I think you will find the reason for failure.
    I'm all for DIY but I wouldn't like to spend the time to find it just pop again.
  11. madmantrapper
    Apr 20, 2011
    15
    sq-aristo
    I've checked all the peak voltages, no surges. I've checked the coils and everything else I can come up with over the years. I think the trouble might be heat related during slow trolling but I'm not sure of that. I also I another outboard that does the same thing. I'm told it is just something that happens.
    Thanks for the thought,
    Paul
