I have a 55 A, 100 V, SCR, TO-218AC in a car battery charger that is obsolete , the closest replacement i can find is a 55 A, 200V, SCR, TO-218AC. How critical is the volts? are there tolerances rules as with capacitors and resisters in +/- where the circuit will still do as design? how high can that voltage rating be raise and it still work? is it like caps where you can use a higher voltage cap but not a lower one? thanks in advance
