I am wanting to control an AC line (~120V, 20A max) (a normal house outlet).
I'm trying to figure out whether a mechanical relay or an SCR would be better. A mechanical relay will probably be bigger in size, and require a bigger current to throw(which will affect the current specs of my AC/DC converter). But, an SCR has an average power dissipation of alot more normally(so I've read).
Is the above correct? Ideally I want to draw little current overtime, so a low power 20A scr would be ideal, but I keep seeing average dissipation of about 0.8W.
Any advice is much appreciated!
