SCR NOT trigger
Discussion in 'General Electronics Chat' started by mostafa_gordy, Apr 9, 2012.
  1. mostafa_gordy
    Feb 28, 2012
    57
    can i replace SCR with mosfet (IRF840) ?
    How do protect mosfet for back emf ?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is very much on topic for All About Circuits, so I moved it to an appropriate forum.
  3. jimkeith
    Oct 26, 2011
    539
    99
    You can replace an SCR with a MOSFET only if you have rectangular triggering--unfortunately, rectangular triggering is not common--it is generally single pulse or pulse train.
    On the schematic provided, it appears that the gate pulse will be too short--to use the MOSFET, you must first determine the ring frequency of the resonant circuit and make sure that the 555 outputs a long enough pulse to run for >½cycle--it also appears that the 555 is wired wrong for astable operation--top of lower 270Ω resistor should connect to pin 7, rather than +12V.
    A series rectifier protects against reverse voltage--this is a common arrangement--for best performance, use fast recovery rectifiers
    My suggestion: Use the SCR--they will work well for the application and do not have the complications introduced with the MOSFET..
  4. mostafa_gordy
    Feb 28, 2012
    57
    hi . firstly, sorry for poor english .
    my bridge diode is blow up(perhaps high current flowing in diode) :confused:and scr is latch up and do not turn off . :mad:
    circuit need resistor ?whats resistor is helpful ? whats location of resistor?
    replace switching section of circuit is need?
    totem-poll ? or push-pull?
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Ignition coil?
    What is this circuit, as in what does it do?
    Have you read our Terms of Service?
  6. mostafa_gordy
    Feb 28, 2012
    57
    yes! but this circuit for other use(study HV)
