Scr motor drive
Discussion in 'Homework Help' started by scratch, Aug 14, 2010.
  1. scratch
    Aug 6, 2010
    38
    can i controll the speed of a lage DC seriese wound brush motor with a SCR.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    A single SCR would only allow you to switch the motor on and unless you have a gate-turn-off SCR you can't then switch off the DC current. SCR's have been used in a forced commutation chopper (PWM) mode but the circuit requirements become more complex to achieve this. A single SCR won't do it - particularly if you have speed control in mind.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This must be realted to your electric vehicle thread.
    A SCR is not made to control DC current. It will simply latch on and stay on until power is removed. Your DC motor needs either a resistive controller (wasteful) or some kind of PWM.
    If you go back to the EV thread, you will find it is still active - just on a different page - http://forum.allaboutcircuits.com/showthread.php?t=41551&page=4
    If you can give more information, help is waiting.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Universal motors (i.e., AC/DC motors) are series wound. I am not sure whether your motor will run on AC. If it does, then you could use an SCR to control it as such controls are quite commonly used for universal motors. Be aware that such controllers do not provide the same high-torque at low speed as PWM DC does for series wound motors.
    Now, where are you going to the the AC?
    John
  5. scratch
    Aug 6, 2010
    38
    thanks very much for help
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    There is a method, called commutation, in which the DC current through an SCR is shunted around it, dropping it to a value below the minimum holding current. Usually accomplished by triggering a second SCR that is in series with a capacitor. General Electric used this method in its industrial variable speed inverters.
