SCR Latching - Mosfet ICs
Skeebopstop
Joined Jan 9, 2009
358
Hi all,
I have been reading the AN attached, and if I understand correctly, SCR latchup in CMOS ICs is only a risk when a P-channel and an N-channel find themselves in close proximity to each other.
Is this a common scenario in most all CMOS ICs or just when you have a push pull output stage?
Regards,
thatoneguy
Joined Feb 19, 2009
6,359
It is an issue with many logic/switch ICs, both MOSFET and transistor based.
Follow the app notes for particularly sensitive devices, usually mentioned in datasheets or app notes.
Use 0.1uF decoupling caps on all ICs to help stabilize power supply.
Avoid running/having inputs near or outside minimum and maximum voltages.
If possible, apply power to ICs before applying input signals.
Skeebopstop
Joined Jan 9, 2009
358
I am quite familiar with practices to avoid it, just not overly familiar at being able to identify susceptible candidates.
Can you elaborate on your first statement? "It is an issue with many logic/switch ICs, both MOSFET and transistor based. "
Is it only when the logic has and P and N channel adjacent pairs? So this can also be a problem for TTL logic? Is it the exact same phenomenon?
Regards
DickCappels
Joined Aug 21, 2008
10,171
Just assume that all devices are susceptible. There has been a lot of progress in the last 30 years in the area of reducing susceptibility, but even with those remedies in place, chips can still latch up given enough current in the wrong place.
