Hello Members,
I am trying to regulate voltage delivered to an inductive load using a Semikron SCR of 100A connected in anti parallel configuartion
I am attaching my circuit for firing scr , the problem is that the scr goes out of control after firing the circuit for about 2 to 3 times for 3 to four cycles (50hz) .It passes full current through the load , though the input is proper 200us pulses.
We are using a pic to generate a 5Khz pulse. R1 & R2 are 10 ohms 1W , I do not know how to calculate it,I have selected it randomly , also if you observe the output it is not proper as per the input, after introducing the diode the spikes were reduced (Which I have not depicted ).
I have used a snubber across the scr .
Please help me , I need some proper write ups about designing a firing card with pulse transformer (1:1:1) ,
With regards
With regards
