SCR Firing help
Discussion in 'General Electronics Chat' started by petervnzla, Oct 21, 2010.
  1. petervnzla
    Oct 21, 2010
    hi..!
    I need guidance. is the first time that I work with SCRs
    I have to build a 3-phase controlled rectifier.
    and don't know how to turn on & off the SCRs.. :confused:
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. petervnzla
    Oct 21, 2010
    thanks.. i know the theory but no the practice.. so, i need to build a control
    circuit for the SCRs and i don't have idea of what to do..
  4. timrobbins
    Aug 29, 2009
    318
    16
    Search on SCR drivers. You will have to do a lot of homework, as a complete operating controller is not simple.
  5. petervnzla
    Oct 21, 2010
    all i need is make a train of pulses for this combination:
    T1 T2 ; T2 T3 ; T3 T4 ; T4 T5 ; T5 T6 ; T6 T1
    and the firing angle have to be variable
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    As you pointed out earlier - that's theory.
    Scratch building a 3-phase controller is a reasonable challenge. Unless you are compelled to build this you would save a lot of time if you buy a dedicated control board off the shelf.
