scr firing circuits
Discussion in 'Embedded Systems and Microcontrollers' started by mukulkr82, May 2, 2010.
  1. mukulkr82
    May 2, 2010
    hi
    actually i have 6 push full wave fully controlled scr firing pulse circuits but its functionality depends on sync. supply.
    my improvement task is "without sync. supply".
    details:
    sync. supply is use for pulse generation through "zero crossing and current controller output", then after IC 4538B is used for dual pulse generation .
    for 6 scr's total 6 op-amp is used as zero crossing dect. circuit.
    total 12 pulse generated for 6 scr.
    one more point is ac power supply and circuit control supply match ( vector group) with small transformer(not power transformer, simple 3 transformer )
    please reply.
    thanks
    Mukul
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This is hard to understand. When you say:
    - does this mean you have an assignment to control the SCR's without reference to the zero crossing detectors?
    Is this a circuit under control of a microprocessor? Can you furnish a block diagram of the desired circuit?
