SCR firing circuit using 555
Discussion in 'The Projects Forum' started by jignacio, Dec 5, 2012.
  1. jignacio
    Nov 20, 2012
    Hi, anybody who could help me building my own battery charger using SCR. I have 2 pcs. of 12 Volts 200Ah battery, our 24 volts battery charger was stolen. I have a 32 volts 30 Amps transformer and I am willing to buy a new SCR also I want to use 555 timer IC to trigger the SCR so that I can adjust the necessary current needed for my battery. Anybody could help me would be very much appreciated. Thanks in advance.
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    Just a naked transformer making 32V AC? Or does it already have a rectifier, filter and regulator making 32V DC?
  3. crutschow
    Mar 14, 2008
    13,482
    3,370
    If you have only a transformer, then you just need a phase-control circuit for the SCR as described here. You don't need to use a 555. Also you don't need to add a capacitor filter on the output since the battery will act as a large capacitor.
    But note that you will likely need to add some inductance or resistance in the circuit to limit the peak current, since the transformer voltage is much higher than your battery voltage. An SCR by itself will not limit this.
    #12 likes this.
  4. #12
    Nov 30, 2010
    16,671
    7,314
    Thanks. I haven't taken a jab at this because I can't figure out why you need a 555 to charge a battery.
  5. wayneh
    Sep 9, 2010
    12,379
    3,232
    +1
    I assumed he was thinking of PWM to control current, but that's just a guess.
  6. crutschow
    Mar 14, 2008
    13,482
    3,370
    Well, AC phase control is a sort of PWM. ;)
