.scr file
Discussion in 'Programmer's Corner' started by dMoser, Nov 29, 2011.
  1. dMoser
    Aug 25, 2011
    30
    In an .scr file, I noticed the following line:
    set_attribute lib_search_path {. ../LIBRARY/LIBS/ } /
    what does the single dot mean at the beginning of the brackets?
    Thanks.
  2. kubeek
    Sep 20, 2005
    4,686
    805
    What kind of scr file? AFAIK .scr is a screensaver executable file which is not plaintext, so what is your scr for?
  3. jimkeith
    Oct 26, 2011
    539
    99
    My take is that it represents an abbreviated pathname as such can be very long and cumbersome
  4. dMoser
    Aug 25, 2011
    30
    its a run file (script) that is run by RTL compiler.
  5. cheezewizz
    Apr 16, 2009
    82
    10
    like jimkeith says it's probably a pathname, the dot (.) is the current working directory usually and two dots (..) is the parent directory. I imagine that's just saying check this directory and also ../library/libs
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    The brackets are a search path for the libraries.
    . means the current directory, it can also be listed as ./
    The line tells the compiler to use libraries from the current directory first, and if not found, check the next path.
