Is there a way to keep the 555 output running when I let go of the momentary switch?
A school project for which you will receive a grade?It's a part of a project.
In that case, you need to post your ideas (schematics, block diagrams, etc) and your understanding of how they work or don't work. You will be guided to solutions. The rate of progress will depend mostly on your ability to do your work.Yes.
The top switch should be "normally closed" and can be reset by breaking the connection. You should also have a resistor between the bottom switch and the scr gate to limit current (check the datasheet to the scr you will use).
I didn't add it to this thread because of how long and lengthy it would be to read. If you'd prefer me to write it all out, I'd be happy to.In that case, you need to post your ideas (schematics, block diagrams, etc) and your understanding of how they work or don't work. You will be guided to solutions. The rate of progress will depend mostly on your ability to do your work.
You mentioned that one of the ideas was to use the SCR to drive the motor, but you didn't show how the SCR is your circuit was driving the motor.I didn't add it to this thread because of how long and lengthy it would be to read. If you'd prefer me to write it all out, I'd be happy to.
by Aaron Carman
by Jake Hertz
by Jake Hertz
