Please help me with this question
Transients are at their worst when the SCR is switched on at
A) 30 °
B) 45°
C) 90
D) 180°
A) 30 °
B) 45°
C) 90
D) 180°
Translation for math impaired people: Where is the slope of the sine wave closest to being a vertical line?Hello,
Where is the voltage step the largest?
I think bertus meant where will the voltage step be the largest when the SCR is switched. That is the point that will cause the largest transient.Translation for math impaired people: Where is the slope of the sine wave closest to being a vertical line?
You have to make an assumption about your supply voltage waveform, e.g. that it is a sine wave with zero phase shift: V=0 at 0° angle. Having done that you can answer the question.Hi
Thank you for your responses no additional information was given on this exam question
Thread starter | Similar threads | Forum | Replies | Date |
K | Identifying transients | Analog & Mixed-Signal Design | 3 | |
Transients in capacitors. | General Electronics Chat | 2 | ||
P | scr causes transients | Power Electronics | 4 | |
Being Frugal: Harvesting Energy from Transients? | Analog & Mixed-Signal Design | 15 | ||
Help me: transients and current ratio calculations | Homework Help | 2 |
by Duane Benson
by Jake Hertz
by Jake Hertz
