New poster here. Found y'all in a google search.
I've been using an old Beckman industrial 9100 100mhz scope. It's been having trace problems. At first it would make popping noises and the trace would disappear. I would tap the top of the scope and it would come back. A few months back I decided to open it up and look for obvious issues. Found broken solder joint and 2watt resistor that had broken loose. I repaired them and it was back to normal.
Then it started developing the popping again, but trace would stay on. Then I turned it on one morning, no trace.......
Hasn't came back on and I've searched for broken solder joints and burnt components. My thoughts are a shorted cap.
I can't find a schematic and Beckman no longer offers support or documents.
Well today I read on this forum about injecting a signal on the z axis to troubleshoot and sure enough, I have a trace!
Without schematic, how should I troubleshoot now?
Start at the trigger controls and work back to its pr supply?
