Scope Telequipment D61A;horizontal position fault
patpin
Joined Sep 15, 2012
401
all ref to frame:
At 156/C5 (after TR31)
C55: 4.23->4.12V (varies with R69);
F: 108: (no effect of R69)
G: 4,8V: (no effect of R69)
pin 10 to chassis
CCW:0V
CW:0V
pin 12 to chassis:100;
no change with R69
Very interesting!!! -- Now we're getting somewhere!:):):)
So here's the deal -- I must be going for today - In the meantime I'll study the schematic in view of the test results and get back to you tomorrow!:cool::cool::cool:
Very best regards
HP:)
patpin
Joined Sep 15, 2012
401
Previously after 3 months I thought I was lazarus. Now the scope is. I have a flikkering image of both channels. In the warming up period they occupied full screen!!! After a few minutes 2/5ths of the screen again. About 20 to 50 times a minute the screen flickers and the lines dissapear for a fraction of a second.
No button has an influence on it. If I turn intensity to less than 6 on a scale of 8 then the baselines are not visible anymore. (This is like it was the last years). If I augment the intensity from 6/8 to 7/8 and to max (8/8) then the baslines of both channels go furher from each other. After 10 minutes the flickering disappeared...I have now a stable screen but only 2/5th's of the screen. Aft 10 minutes flickering again etc. I measured voltage on R69 slider. When lines are at utomst right pos (2/5th's of screen) then O volt; when turning CCW voltages goes slowly to -12V; no interruption besides the flickering mentioned above). When I gently knock on position button or channel I volt/div the flickering alters!! It appears to be the last one i'll have to clean.
But finally still I have only 3/5 th's of the base lines and at the warming up period the lines ware 100% OK.
The original problem remains the same. Only the warming up period might be a clue? Any idea?
Was the scope connected to the mains when you unsoldered/resoldered R68 and R69? If so, it is possible that the electrically 'leaky' soldering iron 'altered' a semiconductor component --- Again, I'll have a close at the schematic and get back to you latter on:):):) --- Those deflection plate readings are very suggestive/interesting!
Best regards
HP:cool:
In the meantime here's something to consider:
Re: post #110 --- Please note that the described symptoms pervade at least three 'systems' (tabulated below):
System: 'Bias' aka 'Z-Axis' aka 'Video' Symptom: Flickering
System: Horizontal deflection Symptom: Insufficient deflection or fulty balance following warm-up
System: Vertical deflection Symptom: Change in baseline position with intensity adjustment during warm-up
The above 'smacks' of readily serviceable power supply issues (Spec: regulation or filter capacitors)...
'See' you later on!:cool::cool::cool:
Do you have ready access to test points 156/G and 156/F ??? (see uper right of schematic in post #114)
If so please verify that 156/G is connected to CRT Socket Pin #10 and 156/F to CRT Socket Pin #12
I checked TR 33 and TR37 again BE and BC 0.7; infinite in reverse.
--Please check for collector to emitter conduction also (CE should test ∞ in both directions) While, in theory, this should be unnecessary -- practice, however, doesn't always agree;)
--Also please double-check TR31
Please see posts #115 & #116
patpin
Joined Sep 15, 2012
401
Best regards
HP:cool:
indeed it is possible that I d'nt disconnected from the mains... but on the other hand the scope is now in the state in which it was before the soldering. So there must be another cause.
I concur with your assesment that the Scope's return to 'partial life' pretty much rules out such damage!:)
Yes they are;
This is truly bizarre! -- Ok... Now that the scope is "working" again -- please check check X1 and X2 (pins #10 and #12) to each other and to chassis ground again --- Please remember to set the 'Time/Div' control to 'Ext X' prior to the test:)
