Scope, is it lying? Why and how?
Discussion in 'General Electronics Chat' started by atferrari, Dec 7, 2012.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,663
    784
    I came to think that my scope is lying to me.
    Settings:
    AC input
    vertical 10 mV / div
    horizontal: 10 ms/div
    There is a board powered by external PSUs.
    If the board IS NOT connected to the PSUs, I do not see anything in the scope.
    With the board connected to the PSUs, but NOT turned on, I get, consistently, in both chanels, a signal as in the picture, no mater what points I touch with the probes even IF BOTH TO GROUND.
    Impossible to get a better picture. Sorry.
    The signal, evidently periodical, appears as having a frequency of 112Hz.
    Mains is 50 Hz thus nothing to do with it.
    The ground clips on the probes are connected to the ground.
  2. kubeek
    Sep 20, 2005
    4,688
    806
    Could be a ground loop, can you post a diagram of your setup, along with the conection of the psu, scope and mains earth?
  3. crutschow
    Mar 14, 2008
    13,488
    3,372
    Looks like it may be PSU switching noise. Where are you looking?
  4. atferrari
    Jan 6, 2004
    2,663
    784
    Both are simple linears with diode bridge and caps.
  5. atferrari
    Jan 6, 2004
    2,663
    784
    Here is the setup.
    My last findings noted there.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Had a similar problem with strange signals riding on what I wanted to look at. Turned out to be a nearby local AM broadcast station and something on the board under test was picking it up.
  7. ErnieM
    Apr 24, 2011
    7,436
    1,626
    A linear supply with full wave rectifiers connected to a 50 Hz line will draw current spikes 100 time a second. There is nothing linear about the diode charging the cap: all the current comes in short bursts of high current as the input wave nears the top.
    With no unit attached there are no bursts as the caps stay charged.
    If this theory is correct you would see similar bursts if you replace the PCB with a simple resistor dummy load.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    So the power supplies only have two-prong plugs on them?
    What about the scope? Is it a two prong-plug and then you have a separate earth ground that you are taking to the power socket?
    Your diagram shows an explicit ground connection as well as a ground connection through the scope's ground connector. Try removing the explicit ground and just have the single-point ground via the mains wiring.
    You might try disconnect each of the four supply leads form your board one at a time (if the circuitry can tolerate that).
  9. atferrari
    Jan 6, 2004
    2,663
    784
    After reinstalling all ICs I turned on the board. The probes to the common, STILL show that signal.
    When probing the different voltages I can see the signal happily riding everything. Nor more nor less what moved me to check all this in the beginning...
    Turned off everything at home except the fridge.
    As suggested in another forum, I also disconnected the earth of the scope. A real mess on the screen with strange artifacts wandering all over.
    By now I run out off ideas. :( As an alternative, growing water lilies instead is not an option. No space around. :)
    That frequency value, steady as it is, doesn't suggest anything?
  10. atferrari
    Jan 6, 2004
    2,663
    784
    I am willing to do any test suggested but am not sure I understand you.
    The signal shows up just with the common connected and no 220V AC power applied.
  11. atferrari
    Jan 6, 2004
    2,663
    784
    Been wondering if would be of any use to check how good is the earth connection at the wall sockets (vocabulary could be wrong - I know).
    Can you tell me how to do it.
    I have a reverent fear of 220 V so I am always very cautious.
  12. kubeek
    Sep 20, 2005
    4,688
    806
    What does your scope show when you connect the ground clip to the tip of the probe?
  13. atferrari
    Jan 6, 2004
    2,663
    784
    Both connected in the air, show nothing.
    Both connected to ground, the signal shown in my OP.
  14. kubeek
    Sep 20, 2005
    4,688
    806
    I am not sure we are on the same wave. Do you mean scope ground or circuit ground? Try simply shorting one of the probes to its ground.
    Also do you use a 1x probe or a 10x probe? What brand/model is your scope and what is the lowest volt/div setting it has? Also check continuity between the probe ground and the chassis and mains ground at the connector.
  15. atferrari
    Jan 6, 2004
    2,663
    784
    Had a break to clear my mind.
    I eliminated the DUT and one PSU.
    The test was made on the remaining one, which is now powered all the time.
    The ground lead croc AND the tip were both hooked to the 0V point - common of the circuit (or, if you like, the CT of the transformer).
    a) No changes; the signal shown in the OP still shows up.
    b) Connecting that point to earth (brought with a wire from the wall socket), in about one second the signal diminishes to become barely distinguishable (if at all).
    All in all what I have now is about 1 mV of noise(?) or maybe less. Yes, I am at the bottom of what my scope can do.
    c) Touching instead the BNC sockets or any part of the case with that wire, nothing happens and the signal stays unchanged.
  16. WBahn
    Mar 31, 2012
    18,085
    4,917
    If I'm following what you just said, it sounds like the scope chassis is not connected to the grounding wire. Try using a wire to connect the scope chassis to the wire going to earth and see what that does.
  17. spinnaker
    Oct 29, 2009
    5,069
    1,176
    I would first measure to see if there is any voltage differential between chassis and ground.
  18. WBahn
    Mar 31, 2012
    18,085
    4,917
    Duh!
    Good point.
    Although, check with what? The scope? A voltmeter may or may not see it, especially if it is average responding. But worth a shot.
  19. spinnaker
    Oct 29, 2009
    5,069
    1,176
    A voltmeter at it's highest setting would probably be safe.
    Hopefully Argentina is not as bad as other parts of the world but it many countries, you have no guarantee that ground is ground.
  20. atferrari
    Jan 6, 2004
    2,663
    784
    No change at all.
    I measured wrt ground prong in the scope's socket, the following resistances:
    BNC sockets: 0.5 Ohms.
    Chassis: 0.4 / 0.5 Ohms.
    Leader probes' ground leads: 1.2 ohms
    Greenpar probe's ground lead: 0.8 Ohms.
    BTW, I simplified things even more testing everything with probe's tip and grounding clip shorted, connected directly to a wire coming for mains' earth.
    Measured AC with my multimeter, between chassis and earth in all ranges up to 750V. Zero, nada.
    Spent the whole Sunday and still here...
    Thanks for helping.
