Below are three different charging methods for a scooter.
Fig. 1 shows the conventional method where the batteries are charged in series
with a single charger.
Fig. 2 shows a series charging method using two 12V chargers. Are there any issue you foresee with this method?
Fig. 3 shows an ideal charging method with two 12V chargers each charging a
single battery. A switch would be used to allow this configuration.
I guess my question is, would you think there would be any issue with the chargers and the motor controller if left directly connected, 110V disconnected of course. In other words I'd like to use the two 12V chargers
as on-board devices just as the single 24V charger is now.
Your expert thoughts and recommendations are appreciated!
