scilab xcos error
Discussion in 'Programmer's Corner' started by rajanragesh, Dec 22, 2010.
  1. rajanragesh
    Jun 25, 2010
    i am using Scilab for simulating flyback and forward converter in a single stage configuration, control system included.
    recently installed scilab 5.3.0.
    in xcos demo, all but electrical and modelica models work.
    i have installed
    visual c++2005 redistributable
    visual c++2008 redistributable -x86 9.0.30729.17
    windows installer 3.1
    lcc-win32 version3.2 (base version) in scilab folder
    also installed MinGW Get version 0.1 -alpha-5 in scilab folder.
    please suggest a way out of this.
    i am getting an error like:
    "Modelica blocks are reduced to a block with:
    Number of differential states: 2
    Number of algebraic states: 1
    Number of discrete time states : 0
    Number of zero-crossing surfaces: 0
    Number of modes : 0
    Number of inputs : 0
    Number of outputs: 2
    Input/output dependency:[T]
    Analytical Jacobian: enabled (%Jacobian=%t)
    Parameter embedding mode: enabled (%Modelica_ParEmb=%t)
    Generated files path: C:\DOCUME~1\admin\LOCALS~1\Temp\SCI_TMP_3220_\"
    in a POP OUT window and
    "Main Modelica : C:\DOCUME~1\admin\LOCALS~1\Temp\SCI_TMP_3220_\RLC_ Modelica_im.mo
    Flat Modelica : C:\DOCUME~1\admin\LOCALS~1\Temp\SCI_TMP_3220_\RLC_ Modelica_imf.mo
    Simulation C code :C:\DOCUME~1\admin\LOCALS~1\Temp\SCI_TMP_3220_\RLC _Modelica_im.c
    Generate a loader file
    Generate a Makefile
    Running the Makefile
    !sorry compiling problem !
    !A Fortran or C compiler is required. ! "
    in the CONSOLE window.
