Hello All,
This is my first post on this forum. I am in a
science competition next month and have to create an
electric, propeller-driven car that travels a meter
in an amount of time that won't be divulged until
after our vehicles are impounded by the judges.
Therefore, we must be able to adjust the car on the
fly at launch time. We have tried a million things
and haven't had a lot of luck. We used a rheostat to
adjust the voltage to the motor. We adjusted the air
intake area of the propeller and even the angle of
the propeller relative to the car but the results
aren't near as constant as we need, sometimes
varying by 30% between runs. We had an epiphany
last night but don't know how to implement it.
At full speed, our car can travel the meter in
about 2 seconds. We thought we might be able to use
an adjustable circuit (maybe an RC with an
adjustable pot) to create a delay between cutting
our car on (the timers start then) and when enough
voltage is delivered to the motor to make it go
(around 6.5 - 7volts). We don't have a lot of
electronics experience so any help would be greatly
appreciated!
Here are the details:
Time requirement: 5 to 15 seconds
Voltage: 9V DC
current: App 4A
Motor/prop: standard speed 400 brushed motor and 5"
prop for small hobby planes.
NO ICs allowed (I guess that means we can use
resistors, capacitors, inductors, diodes etcetera).
We tried studying up on simple RC circuits and even
experimented a bit but we couldn't get the motor to
turn for some reason. We built a simple series
circuit with a 10 ohm resistor and 1000uF cap. We
attached the motor in parallel with capacitor and
calculated that it should've taken app 12sec to
start the motor but the prop just barely turned.
Again, we appreciate whatever you can do for us.
appreciated!
Voltage: 9V DC
current: App 4A
