School project-Sequental LED Lights
Wendy
Joined Mar 24, 2008
23,429
OK, here is the latest changes, if you look in the feedback and suggestions forum you'll see some examples of my protoboard illustrations, this is what I'm aiming for.
Wendy
Joined Mar 24, 2008
23,429
OK, here are the 3 schematics. I'll wire a simplified version to verify the logic.
I'll get back with you...
Wendy
Joined Mar 24, 2008
23,429
I'm currently working on drawing the test bed, which I will then wire. It consists of the 1st and last schematics, which incorporate the standard layout in the middle. Just to show what it might look like I'll post pictures on this post later, with the intent to change it to the final version later.
If the school has an electronics dept. you might see if you can recruit help from there.
Wendy
Joined Mar 24, 2008
23,429
OK, finished drawing the prototype layout. It is spread out a bit to allow easier drawing, I think it might be possible to fit your unit on two prototype board if they were laid out tighter. The green wires are to simulate the switches.
Now to build it.
