schmitt trigger
Discussion in 'Homework Help' started by bug13, May 8, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Q:
    Design and draw the circuit of a non interting Schmitt trigger. It is to operate from a dual 15 volt P.S.U and the output has 0v saturation. The hysteresis required is 0.281v at the upper and lower trip points (i.e. hysteresis = 0.562v). Calculate suitable resistor values.
    and I don't understand the output has 0v saturation part in the question :confused:
  2. WBahn
    Mar 31, 2012
    18,080
    4,917
    I'm not sure what they mean. The only things that makes sense is that they are saying that the difference between the output and the supply rail is 0V when it is saturated.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    I agree. It probably means that the output will swing rail-to-rail, independent of the load. This makes calculations simpler.
